Home > Maintenance & Modifications > 1st to 2nd crunch
Page 2 of 2 <12
Laurie
I've got an Ashcroft R380 box in my TD5 Ninety.
There's very little difference from the original.
Post #147879 31st May 2012 10:43am
ajps72
2001 Defender 110 Td5 SW Chawton White
IMHO I don´t think there will be an additive solution for the crunch, I once read that that the defender has a hesitation gearbox, that means you have to hesitate for a fraction before each gear.
All additives reduce friction and by reducing it you will make the synchro slip instead of transmiting speed to the shaft.
Perhaps ceramic additive could build something that help, but not sure of that since they are load with antifriction.
BTW the liqui moly ceratec says in the bottel that it is for transmissions and engines. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #147906 31st May 2012 12:59pm
Lukey Boy
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Re: 1st to 2nd crunch
The Boy wrote:
I have tried to search but can’t find the answer among the huge amount of posts on this subject but someone here I think said they changed their gearbox oil and in doing so got rid of the first to second crunch.
Of course this may have been some alcohol induce dream I may or may not have had in which case forget I said anything.
Boy
Cluncky 1st to 2nd gear changes. I had the same problem so checked my prop shaft s. Found the bolts loose front end of the rear shaft. This did improve the clunking but yesterday with only a week left on my warrenty decided to get it checked out. Hunters of Norwich found one of my rear half shafts worn so changed it. The gear changes are really smooth now. Any help? 2008 110 XS CSW Stornoway Grey
Post #149238 8th Jun 2012 8:09pm
ajps72
[quote=
Boy[/quote]
Cluncky 1st to 2nd gear changes. I had the same problem so checked my prop shaft s. Found the bolts loose front end of the rear shaft. This did improve the clunking but yesterday with only a week left on my warrenty decided to get it checked out. Hunters of Norwich found one of my rear half shafts worn so changed it. The gear changes are really smooth now. Any help?[/quote]
Interesting to learn that CLONK and CRUNCH are related. Augusto
Discovery 4 TDV6
Post #149489 10th Jun 2012 1:55pm
The Boy
I did have clonking but a new drive flange under warrantee sorted (well made it a little beter) that but did not make a difference to the crunching.
My 07 110 was the same but now this is running so well with the cat removed that the crunching has move up in priority.
Boy
Post #149525 10th Jun 2012 4:10pm
Page 2 of 2 <12
