Home > Maintenance & Modifications > Nakatanenga wheel carrier
kmac
Finally fitted the Nak swing away carrier!!
Nice, and fairly easy to fit. You have to drill one extra hole in the cross member.
Had a couple of issues:
1) Two existing holes used were 8mm but bolts were 10mm - had to enlarge the holes
2) The two long bolts for attaching the carrier to the cross member are two long for my 2009 Puma (see pic below) - have asked Peter at Nak about this - waiting to hear back
P5222129 by kmac9909, on Flickr
P5222131 by kmac9909, on Flickr
Post #146454 22nd May 2012 5:48pm
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
i had the same problem Confused but i didn't use the stainless bolts as they dont get on very well with a mild steel chassis Thumbs Up
Post #146480 22nd May 2012 7:55pm
kmac
Hey you can't stop at that! So what did you use and where did you get it please?
Post #146485 22nd May 2012 8:21pm
Harryb450
I think they were m10x70mm (but im not 100% sure) BZP bolts, i had mine from where i work, but have a look on ebay Thumbs Up
Post #146488 22nd May 2012 8:28pm
kmac
Thanks
Post #146492 22nd May 2012 8:38pm
