![]() | Home > Maintenance & Modifications > Nakatanenga wheel carrier |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Finally fitted the Nak swing away carrier!!
Nice, and fairly easy to fit. You have to drill one extra hole in the cross member. Had a couple of issues: 1) Two existing holes used were 8mm but bolts were 10mm - had to enlarge the holes 2) The two long bolts for attaching the carrier to the cross member are two long for my 2009 Puma (see pic below) - have asked Peter at Nak about this - waiting to hear back ![]() P5222129 by kmac9909, on Flickr ![]() P5222131 by kmac9909, on Flickr |
Hey you can't stop at that! So what did you use and where did you get it please?
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 ![]() ![]() ![]() |
I think they were m10x70mm (but im not 100% sure) BZP bolts, i had mine from where i work, but have a look on ebay
Thanks |
