![]() | Home > Puma (Tdci) > exhaust gasket |
No gaskets on my 2009 110 centre section when I removed it.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
I just did mine today. NO gaskets needed. However, I fit one at the turbo end. Puma 110" SW
chopperpk Member Since: 14 May 2012 Location: sunderland Posts: 32 ![]() ![]() ![]() |
Thanks for that.does it make eney difference just takeing the center box out. cycle
Sound wise no but the engine does seem to rev a little better.
Well i will give it a go.and i will put stainles bolts on cycle
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
oooh no not stainless on a exhaust they get hot and then they biond up horrible
if you do use stainless put plenty of copper slip on them the same with using mild steel ones regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Would u put normal bolts on cycle
yes personaly just put new ones in and give them a coat of copper slip
![]() steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Yer i will probly will thanks
I used stainles steel bolts, copper and shim nuts Puma 110" SW
Or write i
