Home > Puma (Tdci) > exhaust gasket
chopperpk
England 2013 Defender 90 Puma 2.2 HT Tamar Blue
exhaust gasket
Hi there do u no if u need a gasket for the exhaust.im doing away with the senter box and puting a straight throw pipe on.and got a new rear pipe. :twisted:and iv got a 57 plate puma 90 cycle
Post #145978 19th May 2012 8:12pm
bob neville
No gaskets on my 2009 110 centre section when I removed it.
2013 Defender 90 CSW - sold
Post #145980 19th May 2012 8:34pm
MK
I just did mine today. NO gaskets needed. However, I fit one at the turbo end. Puma 110" SW
Post #145983 19th May 2012 8:50pm
chopperpk
Thanks for that.does it make eney difference just takeing the center box out. cycle
Post #146030 20th May 2012 8:25am
chopperpk
Post #146031 20th May 2012 8:35am
bob neville
Sound wise no but the engine does seem to rev a little better.
Post #146037 20th May 2012 8:51am
chopperpk
Well i will give it a go.and i will put stainles bolts on cycle
Post #146039 20th May 2012 8:59am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
oooh no not stainless on a exhaust they get hot and then they biond up horrible
if you do use stainless put plenty of copper slip on them the same with using mild steel ones
regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #146088 20th May 2012 2:08pm
chopperpk
Would u put normal bolts on cycle
Post #146089 20th May 2012 2:16pm
big steve
yes personaly just put new ones in and give them a coat of copper slip Thumbs Up
Post #146090 20th May 2012 2:23pm
chopperpk
Yer i will probly will thanks Thumbs Up cycle
Post #146091 20th May 2012 2:26pm
MK
I used stainles steel bolts, copper and shim nuts Puma 110" SW
Post #146093 20th May 2012 2:54pm
chopperpk
Or write i Embarassed dont now every body is differnt then.but i will copper slip them cycle
Post #146095 20th May 2012 3:16pm
