Home > Puma (Tdci) > Another leak or aircon?
ZeDefender
Now I've sealed the windscreen, I just noticed that the cladding behind all the heater/aircon stuff (central to the foorwells towards the bulkhead) is sopping wet Shocked
The water smells clean and looks clear (i.e. fresh). I also noticed that it gets bloody hot in there.
Could this be due to condensation? The weather here has been bonkers and I've been alternating between aircon and heater these past weeks.
I also read in another thread that someone had water dripping from his heater ducts and had to squeeze his aircon drain nipples. Could the cladding get wet from that? Its about the same height as the fusebox.
Matt Tell someone you love them today because life is short.
Post #145304 16th May 2012 1:09pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Not in my experience. Before I fitted my Entreq snow cowl from Brendan, whenever my drains needed squeezing, the drips came out pretty much smack in the centre of the passengers footwell rubber mat.
Pete
Post #145326 16th May 2012 3:52pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Is the air-con draing properly under the vehicle after a run with it on? Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #145394 16th May 2012 7:38pm
ZeDefender
I think you've got it right there Thumbs Up
It's been raining cats and horses here all day (so aircon off) but 2 hours filthy motorway driving and the cladding is drying out nicely Shocked
Therefore not a leak from outside... I also have a snow cowl.
I haven't noticed aircon draining after a run so I'm going to check all these "drain holes/nipples" tomorrow. Perhaps they were bunged up when waxoyling...
Cheers all
Post #145431 16th May 2012 9:56pm
rossy
next time the aircon has been on for a while stick your head underneath the vehicle (observing all the usual Health and Safety precautions of course!). Water drips right onto the gearbox therefore you will see it trickling down the side (on mine its the driver's side)
Post #145441 16th May 2012 11:30pm
ZeDefender
B*gger it - I've just checked the two drains (under airbox and above gearbox) and they were both okay.
Will wait for nice weather and do as you suggest and hope I can figure something out before the first Stealer service at the end of the month...
Post #145486 17th May 2012 11:04am
