Home > Puma (Tdci) > Under seat boxes |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
You're lucky with just couple of splashes, I had half of Salisbury Plain in my battery compartment
Some of the gaps were massive but now all sealed with Dum Dum Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
15th May 2012 6:16pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5006 |
Definitely seal it
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
15th May 2012 6:22pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20121 |
I thought that may be the case Again why is it not done at the factory? One box is full of electronics and the other a battery it's obvious that water and dirt ect don't mix with batteries and electrical so why let it? Also another question to save putting up a new thread. The lockable clamps on the boxes that hold the lids down do these clamps have a special name or available elsewhere to buy? They'd be ideal for somthing I have in mind regarding the cubby box. Any info would be helpful
15th May 2012 6:29pm |
Overcentre catch, LR part number MRC8388
15th May 2012 6:35pm |
That's the one thanks Bob. (8 in picture below) Click image to enlarge |
15th May 2012 6:41pm |
if you have the land rover standard battery, you should find a small breather pipe from one end of the battery, thru the underseat box, so there should be no problem sealing the box up.
just make sure it's ventilated if you are charging it |
15th May 2012 10:42pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2395 |
Does that pipe replace the other breathers built in the bottom of the box? Puma 110" SW ............................................................. Earth first. Other planets later |
15th May 2012 10:57pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7877 |
i have gone the other way with mine and left all the holes open and made a hole in the bottom too. it will come in and now it will drain out too. Cheers
16th May 2012 7:18am |
Yep standard battery with breather fitted |
16th May 2012 9:48am |
