Home > Puma (Tdci) > Under seat boxes
Under seat boxes
I opened the passenger side under seat box today and noticed a couple of light muddy splashes in there on the battery and that area. I can't help but think it would be a good idea to seal the edges up with some silicone? Or will this cause problems with having no air movement at all i.e. condensation or damp / moisture Question
Post #145130 15th May 2012 6:07pm
bob neville
You're lucky with just couple of splashes, I had half of Salisbury Plain in my battery compartment Shocked
Some of the gaps were massive but now all sealed with Dum Dum Thumbs Up
2013 Defender 90 CSW - sold
Post #145133 15th May 2012 6:16pm
Zagato
Definitely seal it Shocked
Post #145134 15th May 2012 6:22pm
I thought that may be the case Mr. Green Again why is it not done at the factory? One box is full of electronics and the other a battery it's obvious that water and dirt ect don't mix with batteries and electrical so why let it? Rolling Eyes Also another question to save putting up a new thread. The lockable clamps on the boxes that hold the lids down do these clamps have a special name or available elsewhere to buy? They'd be ideal for somthing I have in mind regarding the cubby box. Any info would be helpful Thumbs Up
Post #145140 15th May 2012 6:29pm
bob neville
Overcentre catch, LR part number MRC8388 Thumbs Up
Post #145143 15th May 2012 6:35pm
Bob
That's the one thanks Bob. (8 in picture below)
Post #145148 15th May 2012 6:41pm
if you have the land rover standard battery, you should find a small breather pipe from one end of the battery, thru the underseat box, so there should be no problem sealing the box up.
just make sure it's ventilated if you are charging it Thumbs Up
Post #145222 15th May 2012 10:42pm
MK
Does that pipe replace the other breathers built in the bottom of the box? Puma 110" SW
Post #145224 15th May 2012 10:57pm
jst
i have gone the other way with mine and left all the holes open and made a hole in the bottom too. it will come in and now it will drain out too. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #145239 16th May 2012 7:18am
Yep standard battery with breather fitted Thumbs Up
Post #145278 16th May 2012 9:48am
