Home > Td5 > 1999 110 Defender sunroof
Page 2 of 2 <12
K9F
Thanks Vee Tee you learn something new every day. Thumbs Up
I had a nightmare with my Discovery ones (front and rear) and ended up removing them and totally resealing and fitting new drain tubes. Arduous job but worth the effort as my headlining used to get soaking wet.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #308562 16th Feb 2014 12:55pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
As Vincent say, the Defender roof is just a frame cut into the roof and no drainage pipes.
It's not the glass roof per say on mine that's leaking, but I'm getting water in at roof level (the wet right leg syndrome) and wondered if the frame needs re-sealing.
I've sealed the roof joints in all other areas, so the sun roof is the only one left.
Simon
Post #308805 17th Feb 2014 9:25am
VeeTee
Netherlands
Hi Simon, did you think of this?
http://www.defender2.net/forum/topic22765-11.html Cheers, Vincent
MySite
Post #309031 17th Feb 2014 11:48pm
couplands
Vincent,
I'll give it a try. I thought I'd sealed most holes, but perhaps I'll have another look as per your post..Wink
Simon
Post #309035 17th Feb 2014 11:53pm
Page 2 of 2 <12
