![]() | Home > Technical > Suspension Query |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
i personally would go as tight as you can hey have nylocks so shouldnt come undone you dont really want any play in the bushes
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Officially:
Rear upper 85Nm Rear lower 28Nm Front - When tightening the nuts on both the upper and lower fixings, ensure that at least two threads are visible on the section of the bolt that extends beyond the nut. ![]() Unofficially: Tight is tight; too tight is broken... ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048 ![]() ![]() |
Sorry don't fully understand your post, if you are talking about the top of the rear dampers, then these should be done up nice and tight. But if you are talking about the top of the front dampers (or bottom of front or rear) you should only tighten these enough to start to compress the rubber bushes, over tightening will lead to the bush splitting and going missing.
Andy Reading again you mention "tubular turret's", so you are talking front? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8478 ![]() ![]() ![]() |
what he said ^^^^^^ dont over tighten them. you also compress the rubber and then loose any give in it which reduces the flex and increases wear on articulation. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Baffled 1 Member Since: 09 Feb 2012 Location: Brailes Posts: 37 ![]() ![]() ![]() |
Thanks all for reply, most helpful, you have probably guessed it was the front shocks at the moment but this question was for the rear as well, which I will be tackling later in the week. I have noticed the Terrafirma rubber bushes seems larger than standard but this could be purely down to well worn old bushes. I have been keeping close eye on new rubber bushes as I tightened making sure they are not commpresed to much.
they are wider than std regardless of wear/compression of the old ones. Cheers
