Home > Technical > Suspension Query
Baffled 1
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Suspension Query
Hello All, I have started to replace springs and shocks all round on my 2002 90, it is all standard part from Terrafirma shocks and tubular turret's. I have fitted the first set today all has gone well, but my question is how much should I tight'en the new shocks? is their a recommended torque? I have them bolted up so the first thread is visible on the top and just less on the bottom, as it seemed to be getting tight! did not want to over do it.
Many Thanks
Post #144196 9th May 2012 7:44pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
i personally would go as tight as you can hey have nylocks so shouldnt come undone you dont really want any play in the bushes
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #144215 9th May 2012 8:28pm
wslr
Officially:
Rear upper 85Nm
Rear lower 28Nm
Front - When tightening the nuts on both the upper and lower fixings, ensure that at least two threads are visible on the section of the bolt that extends beyond the nut. Rolling Eyes
Unofficially:
Tight is tight; too tight is broken... Wink
Post #144225 9th May 2012 8:46pm
landy andy
Sorry don't fully understand your post, if you are talking about the top of the rear dampers, then these should be done up nice and tight. But if you are talking about the top of the front dampers (or bottom of front or rear) you should only tighten these enough to start to compress the rubber bushes, over tightening will lead to the bush splitting and going missing.
Andy
Reading again you mention "tubular turret's", so you are talking front?
Post #144227 9th May 2012 8:47pm
jst
what he said ^^^^^^
dont over tighten them.
you also compress the rubber and then loose any give in it which reduces the flex and increases wear on articulation. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #144236 9th May 2012 8:58pm
Baffled 1
Thanks all for reply, most helpful, you have probably guessed it was the front shocks at the moment but this question was for the rear as well, which I will be tackling later in the week. I have noticed the Terrafirma rubber bushes seems larger than standard but this could be purely down to well worn old bushes. I have been keeping close eye on new rubber bushes as I tightened making sure they are not commpresed to much.
Post #144247 9th May 2012 9:15pm
jst
they are wider than std regardless of wear/compression of the old ones. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #144250 9th May 2012 9:20pm
