Home > Puma (Tdci) > New key . . . Anyone noticed any defference |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 |
Hello, just wondering if anyone's noticed that the winkers take a while longer to flash, also, got outta mine yesterday, left keys in as normal, went bk 5 mins later, tried starting, turned over but no fire then was like it had a flat battery, my gues was the immobiliser had kicked in, took keys out, locked and unlocked and started up fine? Cheers jammer 90 Puma HT
5th May 2012 8:23am |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 |
No difference. Yes, immobiliser. You should have seen red indication near bottom of left hand dial.
5th May 2012 9:49am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4497 |
My 2011 Puma came missing one key. I got one ordered in and it was arranged for my nearest dealer to programme it.This is not where I bought the vehicle. When this key is inserted, the red light on the dash stays on and the vehicle will not start. When the lock/unlock blip is used and key inserted and turned, the vehicle starts. This leads me to think it is a programming glitch as the original key works fine. I don't think it is much to worry about, just lock/unlock before you start. 1982 88" 2.25 diesel
5th May 2012 2:46pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
You do have 2 of the " lock/unlock blip's" or FOB's , one for each key? Because it is the FOB which contains the chip/electronics for the engine immobiliser not the key and the FOB has to be close to the antenna in the steering column. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
5th May 2012 9:17pm |
It's a key with built in fob, the group buy jobby 90 Puma HT
6th May 2012 10:16am |
Yep, my second key has the fob, so I still maintain it is a glitch with the programming. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
6th May 2012 10:31am |
In that case you are probably correct. The programming is not correct. LANDYWATCH
6th May 2012 10:46am |
It came with a pod thing to program it?! It does work it's just once this happened?! Just wondered if anyone with the same key had this!? 90 Puma HT
6th May 2012 11:17am |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
Deleted duplicate post - must learn not to use 'previous page' button after posting
6th May 2012 1:17pm |
Try resynchronising the fobs to the 10AS. They do go out of synch sometimes and the pre programmed resynch is to lock and unlock using the fob 4 times.
Click image to enlarge Brian Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
6th May 2012 3:46pm |
