Home > Puma (Tdci) > 500 vs 50 ppm diesel
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
is 500 ppm diesel bad for the 2.4 puma?
Post #143291 4th May 2012 7:17am
Naks
Re: 500 vs 50 ppm diesel
Marius, it can handle it. IIRC, it can handle up to 3000ppm.
But fill up with 50ppm as a rule, it's a much better diesel. I find the best consumption comes from Sasol and Shell Thumbs Up --
Post #143296 4th May 2012 7:44am
Marius
On my way to work there is an Engen and they only have one pump with 50, so I end up filling up 9/10 times with 500. Just wanted to know if will cause damage in the long run? My consumption with 500 Engen is about 11.5 l/100km.
Post #143298 4th May 2012 8:00am
Naks
It won't.
However, higher sulphur content means more sulphuric acid in the oil. Just change the oil every 10,000km to get rid of the sulphuric acid build up --
Post #143299 4th May 2012 8:03am
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
The main problem using 500ppm is that it stuffs up the DPF, which isn't installed on SA vehicles. But Naks is correct about the acid build up when using 500ppm. The service schedule states that if you use 500ppm then you should reduce oil changes to 10k. Fill up with 50ppm where you can.
Post #143306 4th May 2012 8:56am
Naks
the 2.2 Puma has a DPF, so be careful --
Post #143308 4th May 2012 9:02am
robharvey
Not in South Africa.
Post #143311 4th May 2012 9:04am
Naks
Oh, didn't know this. Good to know Thumbs Up --
Post #143312 4th May 2012 9:04am
Marius
ok......50ppm it will have to be then.
I live 4 km from work so I end up getting to 1 year before I get to 20k. Had my first years service at 12k so, should be ok with the acid buildup then.
Post #143323 4th May 2012 10:44am
Naks
Not that great to do such short distances every day. I would take it out on the open road at least once a week to give horns Thumbs Up --
Post #143327 4th May 2012 11:00am
bwanashamba
2011 Defender 130 Puma 2.4 HCPU Alpine White
here in Tanzania diesel fuel is all 5000ppm except BP which is 500ppm,where we are we cant get BP Big Cry The dealer insists that service is done every 5000km to stay in warrenty, so far no problems with the high sulpher fuel, on about 16000km now Smile
Post #143344 4th May 2012 12:58pm
