![]() | Home > Maintenance & Modifications > Winch cover |
pjh Member Since: 23 Nov 2010 Location: West Yorkshire Posts: 126 ![]() ![]() ![]() |
Hi,
I've go a Warn 9.5Ti winch on Land Rover winch bumper. The winch is tight up against the radiator grill (it does have air con), has anyone fitted a winch cover? I was thinking of on of these? www.firstfour.co.uk/item/2129314/warn-neop...i--amp--si Do they fit? Any other recommendations? Kind regards, Peter Defender 11MY USW |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048 ![]() ![]() |
I have the warn cover, un wrapped, never used. Pm if you fancy it.
Andy |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
I have a similar winch on the 110, and gave up with the normal use of the cover, found the winch was always damp / wet, mainly due to condensation,
I cut my grill to get it to fit properly ![]() Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Did not need to cut grill on mine
![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Do you have aircon fitted ? Because I bet Tim has ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Yep air con on mine as is an X-Tech.
As does Tim as you can see the plumbing for it |
In that case Tim must have got a deal and bought a non aircon bumper
Hi Landy Andy,
I've sent you a pm. Many thanks, Peter Defender 11MY USW |
You know me to well Matt ![]() Without going OT to much,, think i when through this before The genuine winch/bumper on mine, was originally fitted by a main dealer to a 54 plate TD5 XS with AC,, Now i recon, they fitted a non AC bumper bar, then "made" it fit, hence the grill cut,, No big deal for me,,as i have a better approach angle with it set back a inch or 2 , ![]() In general, recon the cover is worth having,, used mine last in Morocco, to keep the dust out,, but not been on since California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
The land rover instructions do say that the grill needs to be cut, but when I tried mine, I found no need too
![]() My cover looks like this one http://www.flickr.com/photos/mwhcvt/5384356054/in/photostream/ http://www.flickr.com/photos/mwhcvt/5383755099/lightbox/ |
