Home > Maintenance & Modifications > Winch cover
pjh
Winch cover
Hi,
I've go a Warn 9.5Ti winch on Land Rover winch bumper. The winch is tight up against the radiator grill (it does have air con), has anyone fitted a winch cover?
I was thinking of on of these?
www.firstfour.co.uk/item/2129314/warn-neop...i--amp--si
Do they fit? Any other recommendations?
Kind regards,
Peter Defender 11MY USW
Post #143107 2nd May 2012 11:08pm
leeds
Peter, speak to Chris at Electric winch shop, 01274 680744.
He stocks Warn accessories so should be able to answer your questions.
Brendan
Post #143110 2nd May 2012 11:19pm
landy andy
I have the warn cover, un wrapped, never used. Pm if you fancy it.
Andy
Post #143127 3rd May 2012 7:15am
TJ101
I have a similar winch on the 110, and gave up with the normal use of the cover, found the winch was always damp / wet, mainly due to condensation,
I cut my grill to get it to fit properly
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #143139 3rd May 2012 9:05am
landy andy
Did not need to cut grill on mine
Post #143148 3rd May 2012 10:44am
Do you have aircon fitted ? Because I bet Tim has Whistle :mrgreen:
Post #143150 3rd May 2012 10:47am
landy andy
Yep air con on mine as is an X-Tech.
As does Tim as you can see the plumbing for it
Post #143151 3rd May 2012 10:48am
In that case Tim must have got a deal and bought a non aircon bumper Rolling with laughter
Post #143152 3rd May 2012 10:52am
pjh
Hi Landy Andy,
I've sent you a pm.
Many thanks,
Post #143218 3rd May 2012 5:48pm
TJ101
FCX.ME.UK wrote:
Do you have aircon fitted ? Because I bet Tim has Whistle Mr. Green
You know me to well Matt Razz
Without going OT to much,, think i when through this before
The genuine winch/bumper on mine, was originally fitted by a main dealer to a 54 plate TD5 XS with AC,,
Now i recon, they fitted a non AC bumper bar, then "made" it fit, hence the grill cut,,
No big deal for me,,as i have a better approach angle with it set back a inch or 2 , Thumbs Up
In general, recon the cover is worth having,, used mine last in Morocco, to keep the dust out,, but not been on since California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #143221 3rd May 2012 6:01pm
landy andy
The land rover instructions do say that the grill needs to be cut, but when I tried mine, I found no need too Question
My cover looks like this one
http://www.flickr.com/photos/mwhcvt/5384356054/in/photostream/
http://www.flickr.com/photos/mwhcvt/5383755099/lightbox/
Post #143249 3rd May 2012 8:42pm
