![]() | Home > Puma (Tdci) > Gear box noise - idling in neutral |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
Likely to be the friction plate. Second chance is the input shaft´s bearing (more unlikely). Puma 110" SW
tmcwhirter Member Since: 02 Dec 2010 Location: UK Posts: 23 ![]() ![]() ![]() |
Thks for response. So if its the friction plate, thats just a matter of adjusting the play then?
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 ![]() ![]() ![]() |
New clutch
![]() 110 HCPU Tipper |
Thanks - that's what I was after. Won't be taking no for an answer with the warrantee coming up. Only got 15k miles on it!
If it turns to be the clutch please tryto cast your vote here http://www.defender2.net/forum/topic12243.html
A pic from the plate would be also appreciated ![]() ............................................................. Earth first. Other planets later |
Will do
billewizz Member Since: 16 Sep 2011 Location: north lincs Posts: 68 ![]() ![]() |
run a gt3rs and listen to that on tick over, the whole world sounds like a swiss watch.
