![]() | Home > Technical > High HTHS vs low HTHS |
See and decide...
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
what ?
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
right over my head that. Too many words longer than marmalade
![]() But next time I go to Halfords I'll take a printout of this thread, show it to their Saturday lad and say 'Give me an oil that does all that stuff please !' |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
And the reply will be "do you want fries with that?" If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
What's the HTHS of the Castrol Magnatec A1 Professional that the stealers use? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Total base number (TBN) is a measure of a lubricant's reserve alkalinity. It is measured in milligrams of potassium hydroxide per gram (mg KOH/g). TBN determines how effective the control of acids formed will be during the combustion process. The higher the TBN, the more effective it is in suspending wear-causing contaminants and reducing the corrosive effects of acids over an extended period of time. The associated measurement ASTM D2896 and ASTM D4739-06 generally range from 6-80mg KOH/g in modern lubricants, 7-10mg for general automotive use and 10-15 for Diesel operations. Marine grade lubricants generally will run from 15-50mgKOH/g, but can be as high as 70 or 80mg KOH/g. This high level is designed to allow a longer operating period between lubricant changes under harsh operating conditions. When the TBN is measured at 2mg KOH/g or less the lubricant is considered inadequate for engine protection, and is at risk for allowing corrosion to take place. Fuels containing a higher amount of sulfur will decrease the TBN sooner due to the increased formation of sulfuric acid. HTH Brian. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2482 ![]() ![]() ![]() |
something like 3.0 or 3.1. Puma 110" SW ............................................................. Earth first. Other planets later |
thanks. Not too bad then? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
