Home > Technical > High HTHS vs low HTHS
dgardel
Italy
See and decide...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #141287 23rd Apr 2012 11:05pm
MK
Thanks for the info. Very good.
I thought though all <3.5mPas were low HTHS oils.
By the way I just got my lab results today and it was good with 7.000km on it. Mostly highway driving.
A bit surprised with such a high TBN.
Metales (ppm)
Aluminio (Al) s 5
Plata (Ag) s <1
Cromo (Cr) <1
Cobre (Cu) s 1
Hierro (Fe) s 14
Niquel (Ni) s <1
Plomo (Pb) s <1
Estaño (Sn) s <1
Contaminantes / Aditivos (ppm)
Zinc (Zn) s 1367
Silicio 4
Fósforo (P) s 1024
Potasio (K) s <1
Magnesio (Mg) s 96
Molíbdeno (Mo) s 236
Sodio (Na) s <1
Boro (B) s 18
Bario (Ba) s <1
Calcio (Ca) s 2712
Pruebas Fisicas
% Agua <0.1
% Glicol (FTIR) <0.1
Nitración (Abs/cm) 7.1
Sulfatación (Abs/cm) 21.8
Oxidación (Abs/cm) 14.5
Viscosidad (cSt,100°C) s 9.1
Indice PQ <10
% Hollín (FTIR) 0.3
Dispersancia s Pasa
Flash Point a 180C (ASTM D3828) Negativo
Physical Tests
TBN mgKOH/gr (FTIR) 11.6 Puma 110" SW
Post #141296 24th Apr 2012 1:23am
pom
what ?
Post #141359 24th Apr 2012 11:44am
rossy
right over my head that. Too many words longer than marmalade Laughing
But next time I go to Halfords I'll take a printout of this thread, show it to their Saturday lad and say 'Give me an oil that does all that stuff please !'
Post #141801 25th Apr 2012 10:19pm
noworries4x4
And the reply will be "do you want fries with that?" If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #141814 25th Apr 2012 11:01pm
Naks
What's the HTHS of the Castrol Magnatec A1 Professional that the stealers use? --
Post #142546 30th Apr 2012 9:35am
Lorryman100
pom wrote:
what ?
Total base number (TBN) is a measure of a lubricant's reserve alkalinity. It is measured in milligrams of potassium hydroxide per gram (mg KOH/g).
TBN determines how effective the control of acids formed will be during the combustion process. The higher the TBN, the more effective it is in suspending wear-causing contaminants and reducing the corrosive effects of acids over an extended period of time. The associated measurement ASTM D2896 and ASTM D4739-06 generally range from 6-80mg KOH/g in modern lubricants, 7-10mg for general automotive use and 10-15 for Diesel operations.
Marine grade lubricants generally will run from 15-50mgKOH/g, but can be as high as 70 or 80mg KOH/g. This high level is designed to allow a longer operating period between lubricant changes under harsh operating conditions. When the TBN is measured at 2mg KOH/g or less the lubricant is considered inadequate for engine protection, and is at risk for allowing corrosion to take place. Fuels containing a higher amount of sulfur will decrease the TBN sooner due to the increased formation of sulfuric acid.
HTH Brian.
Post #142551 30th Apr 2012 10:48am
MK
something like 3.0 or 3.1. Puma 110" SW
Post #142573 30th Apr 2012 3:09pm
Naks
thanks.
Not too bad then? --
Post #142574 30th Apr 2012 3:17pm
