Home > Puma (Tdci) > Finding something new on my Landy
Ninetenths
2007 Defender 110 Puma 2.4 XS CSW Java Black
Embarassed Ive only just realised that I can plug my ipod directly into the stereo. sorry just very excited, no longer have to mess about with crappy transmitters.
Post #10201 25th Apr 2009 8:27pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
I can't do that with mine. Theres nothing under the little plastic cover. Is yours a standard radio or have you got an upgraded model? I noticed last year (when i removed it) that the build date sticker on the side of the radio was 2004. Typical LR. 130 crew cab
98 V8 Disco
Post #10203 25th Apr 2009 8:34pm
Ninetenths
Unmarked Aux in 3.5mm stereo jack socket under auto button. It is in handbook Embarassed but I never read them.
Post #10204 25th Apr 2009 8:45pm
parktag
I knew about that one, i thought you could use the one under the cover. My ECU interferes with the radio reception quite badly so i'm probably going to change the radio anyway. By the way i never look at the manual until i've tried every button first or broken something. 130 crew cab
98 V8 Disco
Post #10208 25th Apr 2009 9:36pm
dgardel
Italy
Post #10218 25th Apr 2009 11:04pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Lucky you, the Australia spec models have a cheaper version of the radio with no Aux jack hole just a plastic blank where it would have been Crying or Very sad Crying or Very sad
So have to put up with a iPod radio transmitter option - only issue is the wiper motor interferes with that Crying or Very sad 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #10219 25th Apr 2009 11:07pm
mse
there are 2 radio versions - one with one without (well certainly in the UK)
There is also an ipod connection pack i understand to plug in the rear.
The later MP3 radios are new so shouldnt be made before 06 Mike
Post #10222 25th Apr 2009 11:22pm
Eduardo
Here it comming without radio, I have a cheap Sony but with Aux jack
Cheers Eduardo
Post #10224 25th Apr 2009 11:51pm
dm_td5
If you look at the LR fitting guide you'll see that the iPod connection pack is a radio re-transmitter that plugs in line with the aerial. Why didn't LR just put a better head unit? 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #10227 26th Apr 2009 10:00am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Money, Money, Money. We replaced the speakers and the headunit. LR want like 150£ for the ipod adapter to plug into the rear. Shocked may as well just buy a better head unit Smile 110 Tdci Double Cab
Post #10230 26th Apr 2009 12:08pm
mse
There is definately one that plugs into the back and does not use the FM to transmit Mike
Post #10233 26th Apr 2009 12:25pm
murrayb
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Java Black
I plugged my iPod into the stereo and could hardly hear anything. Turned up the volume to max and still terrible. Mad
THEN someone pointed out that it might be an idea to turn the volume up on the ipod Idea Doh ! Embarassed
Post #11152 21st May 2009 8:22am
Grockle
On our i pod when we try to tune it to an unused fm channel we get quite alot of interferance, any answers ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #11225 23rd May 2009 7:53am
mse
You havent got it on charge or by the transmission have you?
Only reason i ask is when i plug the phone in and its near that or getting power from the car there is interference (not that bad though) Mike
Post #11227 23rd May 2009 9:29am
Martin
Site Admin
Are you using the headphone socket to get the audio out of the iPod?
Post #11231 23rd May 2009 9:48am
