![]() | Home > Puma (Tdci) > Finding something new on my Landy |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
I can't do that with mine. Theres nothing under the little plastic cover. Is yours a standard radio or have you got an upgraded model? I noticed last year (when i removed it) that the build date sticker on the side of the radio was 2004. Typical LR. 130 crew cab
98 V8 Disco |
Ninetenths Member Since: 26 Mar 2009 Location: Sarf Lundun Posts: 161 ![]() ![]() |
Unmarked Aux in 3.5mm stereo jack socket under auto button. It is in handbook
I knew about that one, i thought you could use the one under the cover. My ECU interferes with the radio reception quite badly so i'm probably going to change the radio anyway. By the way i never look at the manual until i've tried every button first or broken something. 130 crew cab
98 V8 Disco |
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
there are 2 radio versions - one with one without (well certainly in the UK)
There is also an ipod connection pack i understand to plug in the rear. The later MP3 radios are new so shouldnt be made before 06 Mike |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Here it comming without radio, I have a cheap Sony but with Aux jack
Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
If you look at the LR fitting guide you'll see that the iPod connection pack is a radio re-transmitter that plugs in line with the aerial. Why didn't LR just put a better head unit? 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
Money, Money, Money. We replaced the speakers and the headunit. LR want like 150£ for the ipod adapter to plug into the rear.
There is definately one that plugs into the back and does not use the FM to transmit Mike |
murrayb Member Since: 20 May 2009 Location: Hastings Posts: 20 ![]() ![]() ![]() |
I plugged my iPod into the stereo and could hardly hear anything. Turned up the volume to max and still terrible.
![]() THEN someone pointed out that it might be an idea to turn the volume up on the ipod ![]() ![]() |
On our i pod when we try to tune it to an unused fm channel we get quite alot of interferance, any answers ? 2.4 90 XS
You havent got it on charge or by the transmission have you? Only reason i ask is when i plug the phone in and its near that or getting power from the car there is interference (not that bad though) Mike |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6707 ![]() ![]() ![]() |
Are you using the headphone socket to get the audio out of the iPod? |
