Home > Technical > Instrument binnacle back lighting gone!
Buzz
2010 Defender 110 Puma 2.4 DCPU Tonga Green
As per the subject! Any ideas? It's not a fuse as farad I can see.
Post #136202 2nd Apr 2012 9:04am
More than likely dash illumination bulb blown or failing that a loose connection. Is it only in one area specifically? Thumbs Up
Post #136216 2nd Apr 2012 10:31am
probably a loose wire because the puma dashboards are all lit with LEDs
Post #136230 2nd Apr 2012 11:57am
Buzz
Aye, just the 3 clocks illumination.
Post #136240 2nd Apr 2012 12:54pm
All of them? I thought it was just the 2.2's that had LED?
Post #136241 2nd Apr 2012 12:56pm
mine's a 2010 2.4 I replaced the dashboard when I imported it, when replacing the KPH to MPH decal, all LEDs were visible on the circuit board.
Not sure about the central switch console - filaments or LEDs. It's the same unit on FL2 also, so it's probably been around since FL2
Post #136244 2nd Apr 2012 1:01pm
Buzz
Just checked, it's the three round displays and the headlight and side light warning lamp.
Post #136256 2nd Apr 2012 1:24pm
Buzz
Fixed, my son spotted a side light out, same at back, turned out it was a fuse and it's some how linked to the instrument back lighting! Smart move Land Rover!
Post #136617 3rd Apr 2012 7:46pm
wow - that's worth remembering ... thanks for the update Thumbs Up
Post #136639 3rd Apr 2012 8:26pm
Buzz
A weird one for sure!
Post #136966 4th Apr 2012 9:18pm
LRSoffroad
I Have found that the wire is very thin and have had a few in with internal brakes in the wire , so when you move the wire the lights come on a pain to find , untill i have a few in , also on the Puma heater control,s had the same problems ,
Post #136989 4th Apr 2012 9:43pm
