![]() | Home > Technical > Instrument binnacle back lighting gone! |
Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235 ![]() ![]() |
As per the subject! Any ideas? It's not a fuse as farad I can see.
probably a loose wire because the puma dashboards are all lit with LEDs
Aye, just the 3 clocks illumination.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20841 ![]() ![]() |
All of them? I thought it was just the 2.2's that had LED? |
mine's a 2010 2.4 I replaced the dashboard when I imported it, when replacing the KPH to MPH decal, all LEDs were visible on the circuit board. Not sure about the central switch console - filaments or LEDs. It's the same unit on FL2 also, so it's probably been around since FL2 |
Just checked, it's the three round displays and the headlight and side light warning lamp.
Fixed, my son spotted a side light out, same at back, turned out it was a fuse and it's some how linked to the instrument back lighting! Smart move Land Rover!
wow - that's worth remembering ... thanks for the update
A weird one for sure!
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 ![]() ![]() |
I Have found that the wire is very thin and have had a few in with internal brakes in the wire , so when you move the wire the lights come on a pain to find , untill i have a few in , also on the Puma heater control,s had the same problems ,
