![]() | Home > Technical > Ignition live in Puma engine bay |
Depends on what you're going to run, current draw and where? In the cab, at the front of the vehicle at the rear etc....'pm' sent.
![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 31st Mar 2012 4:27pm. Edited 1 time in total |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
There is one under the drivers seat. There is a single fuse with a brown and orange wire one side and a brown on the other. I cant up load pictures at the moment cause I have exceeded my allocated space
![]() ![]() ![]() OK ignore the above I didn't read the title properly ![]() ![]() |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
Just a set of DRL/Side lights that need an ignition live wire connected to the DRL relay. I assume I could go through the bulkhead for the ignition switch , radio or cigar lighter but I'm loathed to try and put a wire through the bulkhead as I've no leaks ( so far )... ![]() Any ideas much appreciated ![]() Stu |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20921 ![]() ![]() |
I'll tell you a good spot that you could get it throug and that is where the heater re-circulation control cable goes. Accessable from behind offside front speaker from inside and just behind the blower / fan actuator arm in the top right of the engine bay ![]() |
[/quote]
I'll tell you a good spot that you could get it throug and that is where the heater re-circulation control cable goes. Accessable from behind offside front speaker from inside and just behind the blower / fan actuator arm in the top right of the engine bay ![]() Great thanks, I'll take a peek tomorrow ![]() Stu |
i was thinking of using a VSR to detect ignition on and take a feed from the battery for aux items
