Home > Technical > Ignition live in Puma engine bay
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Apart from running a feed off the alternator rear has anyone found an 'easily accessible' ignition live point/wire I can tap into.
ta
Stu
Post #135885 31st Mar 2012 3:15pm
K9F
Depends on what you're going to run, current draw and where? In the cab, at the front of the vehicle at the rear etc....'pm' sent. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #135895 31st Mar 2012 4:19pm
AndrewS
There is one under the drivers seat. There is a single fuse with a brown and orange wire one side and a brown on the other. I cant up load pictures at the moment cause I have exceeded my allocated space Shocked Big Cry Big Cry
OK ignore the above I didn't read the title properly Embarassed 130's have feeling's as well you know Smile
Post #135896 31st Mar 2012 4:25pm
Honker
K9F wrote:
Depends on what you're going to run, current draw and where? In the cab, at the front of the vehicle at the rear etc.... Thumbs Up
Just a set of DRL/Side lights that need an ignition live wire connected to the DRL relay. I assume I could go through the bulkhead for the ignition switch , radio or cigar lighter but I'm loathed to try and put a wire through the bulkhead as I've no leaks ( so far )... Smile
Any ideas much appreciated Thumbs Up
Stu
Post #135898 31st Mar 2012 4:31pm
Stu
I'll tell you a good spot that you could get it throug and that is where the heater re-circulation control cable goes. Accessable from behind offside front speaker from inside and just behind the blower / fan actuator arm in the top right of the engine bay Thumbs Up
Post #135905 31st Mar 2012 5:11pm
Honker
[/quote]
I'll tell you a good spot that you could get it throug and that is where the heater re-circulation control cable goes. Accessable from behind offside front speaker from inside and just behind the blower / fan actuator arm in the top right of the engine bay Thumbs Up[/quote]
Great thanks, I'll take a peek tomorrow Thumbs Up
Stu
Post #135907 31st Mar 2012 5:27pm
i was thinking of using a VSR to detect ignition on and take a feed from the battery for aux items
Post #135963 31st Mar 2012 8:32pm
