![]() | Home > Technical > Fitting a CD Player/Radio |
so what you are saying is you have a defender with no wiring for a radio/cd unit?
You will need the following : > Positive fused feed > Ground / Negative feed > Ariel > +/- for front left speaker > +/- for front right speaker > +/- for rear left speaker > +/- for rear right speaker depending on your head unit, you may need USB extension leads, GPS leads? Upto you if you wire the radio to an ignition live or constant live the ford units turn themselves off after an hour if the ignition is off I don't have any picures, most of the defenders on here are new(ish) and have the required wiring already installed. there are wiring diagrams but for a 1988 they will have changed a bit good luck with install ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Couldn't have said it much better myself ![]() ![]() |
The Musketeer Member Since: 07 Feb 2012 Location: United Kingdom Posts: 193 ![]() ![]() ![]() |
Fantastic! Thanks very much for that, very helpful. I appreciate that most guys on here are running much newer rigs than mine. If it wasn't for the insurance difference, I'm 18, I would be too! I'll update as I go, but hopefully get it done in the next week or two. Sam Good things come to the wild and free |
no problem Sam
So are you ok with running the ariel lead from the wing top through the bulk head ? the +ve - might be worth putting a new aux fuse box in, Leeds and mobilecentre sell nice ones, good investment because your truck won't catch fire ![]() -ve - find a ground point, don't just tag it anywhere, there are a number of earthing points. speakers - wires to the rear could be run in the channels above the doors have fun ! |
That was my plan. Any issues or other reccomendations?
1) When you talk about +ve and -ve, what do you mean? ![]() ![]() 2) Tempted with the 6 way unit from Leeds... that or the 12.
Current thinking on speakers is either; A) Above the seat belt hanger and under the side/back windows (if that makes sense) B) under the dash in the "proper" place and under the side/back windows. Wires run around the guttering and down the back door to rear panels, I think. My next door neighbour is a bit of an mechanical whiz, he does classic car maintenance and hire, so i think I might bribe him with some beer... electrics are not my strong point! Good things come to the wild and free |
You may find that radios require 2 power feeds, one permanent live and one live with ignition. The permanent live enables the radio to keep all the presets stored so you don't have to retune every time you switch it on. Main thing is to make sure you have fuses fitted on all the power feeds
+ve = positive / red
-ve = negative / black, your truck is -ve earth, so the whole of your truck is -ve keep the wires away from anything that could damage them, wiper mechanisms, and if you are putting speakers in the doors use some convoluted tubing to protect the wires. |
I'm 20 and done a fair bit of Defender wiring (but not your purpose) As others have said the absolute priority is to have everything safely fused. Use appropriate Amp rating fuses and also cabling. As BP mentions the whole vehicle will be - Negative. A good earthing point would be somewhere that is either the chassis or something in direct connection with the chassis i.e. bulk head or something similar. If ever you want some extra info you could always drop me a PM and I'd try and help out with as much info as I could manage. ![]() |
For everything else there's K9F
Stitched up like a kipper! ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
No more comments of my miss-understanding of how relays work either ![]() ![]() ![]() |
![]() ![]() ![]() ![]() No offence meant or implied Kona! ![]() Treat every day as if it is your last....one day you will be right!! |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 ![]() ![]() ![]() |
Most importantly you will need a Radio mounting console, the genuine LR is cheap but you have to strip the dash to fit it properly and theres not a lot of space for wiring, there are one or two after market options worth considering.
Regarding power supply you should be able to pick up a permanent and switched supply from the wiring inside the console behind the cigar lighter / wash wipe switch. Richard Either a 90, 110 or 130. Discovery 5 |
