Home > Technical > Fitting a CD Player/Radio
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
Has anyone got any pictures of fitting a full head unit/speaker/aerial to a Defender that hasn't currently got any wiring?
I have a vague idea of what I want to do... but would just appreciate a bit more help! Good things come to the wild and free
Post #135226 28th Mar 2012 8:59pm
so what you are saying is you have a defender with no wiring for a radio/cd unit?
You will need the following :
> Positive fused feed
> Ground / Negative feed
> Ariel
> +/- for front left speaker
> +/- for front right speaker
> +/- for rear left speaker
> +/- for rear right speaker
depending on your head unit, you may need USB extension leads, GPS leads?
Upto you if you wire the radio to an ignition live or constant live
the ford units turn themselves off after an hour if the ignition is off
I don't have any picures, most of the defenders on here are new(ish) and have the required wiring already installed. there are wiring diagrams but for a 1988 they will have changed a bit
good luck with install Thumbs Up
Post #135240 28th Mar 2012 9:11pm
> Positive fused feed
> Ariel
Couldn't have said it much better myself Thumbs Up Thumbs Up
Post #135249 28th Mar 2012 9:21pm
The Musketeer
> Positive fused feed
> Ariel
Fantastic! Thanks very much for that, very helpful. I appreciate that most guys on here are running much newer rigs than mine. If it wasn't for the insurance difference, I'm 18, I would be too!
I'll update as I go, but hopefully get it done in the next week or two.
Sam Good things come to the wild and free
Post #135254 28th Mar 2012 9:30pm
no problem Sam
So are you ok with running the ariel lead from the wing top through the bulk head ?
the +ve - might be worth putting a new aux fuse box in, Leeds and mobilecentre sell nice ones, good investment because your truck won't catch fire Thumbs Up
-ve - find a ground point, don't just tag it anywhere, there are a number of earthing points.
speakers - wires to the rear could be run in the channels above the doors
have fun !
Post #135258 28th Mar 2012 9:34pm
The Musketeer
bpman wrote:
no problem Sam
That was my plan. Any issues or other reccomendations?
1) When you talk about +ve and -ve, what do you mean? Embarassed Confused
2) Tempted with the 6 way unit from Leeds... that or the 12.
Current thinking on speakers is either;
A) Above the seat belt hanger and under the side/back windows (if that makes sense)
B) under the dash in the "proper" place and under the side/back windows.
Wires run around the guttering and down the back door to rear panels, I think. My next door neighbour is a bit of an mechanical whiz, he does classic car maintenance and hire, so i think I might bribe him with some beer... electrics are not my strong point! Good things come to the wild and free
Post #135262 28th Mar 2012 9:43pm
JWL
You may find that radios require 2 power feeds, one permanent live and one live with ignition. The permanent live enables the radio to keep all the presets stored so you don't have to retune every time you switch it on. Main thing is to make sure you have fuses fitted on all the power feeds
Post #135269 28th Mar 2012 10:01pm
+ve = positive / red
-ve = negative / black, your truck is -ve earth, so the whole of your truck is -ve
keep the wires away from anything that could damage them, wiper mechanisms, and if you are putting speakers in the doors use some convoluted tubing to protect the wires.
Post #135281 28th Mar 2012 10:20pm
> Positive fused feed
> Ariel
Sam
I'm 20 and done a fair bit of Defender wiring (but not your purpose) As others have said the absolute priority is to have everything safely fused. Use appropriate Amp rating fuses and also cabling. As BP mentions the whole vehicle will be - Negative. A good earthing point would be somewhere that is either the chassis or something in direct connection with the chassis i.e. bulk head or something similar. If ever you want some extra info you could always drop me a PM and I'd try and help out with as much info as I could manage. Thumbs Up
Post #135293 28th Mar 2012 10:38pm
For everything else there's K9F Laughing Thumbs Up
Post #135294 28th Mar 2012 10:39pm
K9F
Stitched up like a kipper! Laughing Any probs drop me a 'pm,' I'll stick it in my 'tuit' basket and get round 'to it' when I can. Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #135487 29th Mar 2012 5:50pm
No more comments of my miss-understanding of how relays work either Embarassed Wink Laughing
Post #135491 29th Mar 2012 6:06pm
K9F
Rolling with laughter Rolling with laughter Or clocks.... taking recent experience into account! Rolling with laughter Rolling with laughter
No offence meant or implied Kona! Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #135494 29th Mar 2012 6:21pm
Rolling with laughter What was messing me up was the relay configuration instead of it being a 4 pin with say 30 and 87 opposite and 85 and 86 opposite. Then wondered why it wasn't working even though I had it right. Got very annoyed broke it open and found it was knackered anyway Rolling Eyes Laughing
Post #135496 29th Mar 2012 6:34pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Most importantly you will need a Radio mounting console, the genuine LR is cheap but you have to strip the dash to fit it properly and theres not a lot of space for wiring, there are one or two after market options worth considering.
Regarding power supply you should be able to pick up a permanent and switched supply from the wiring inside the console behind the cigar lighter / wash wipe switch. Richard
Either a 90, 110 or 130.
Discovery 5
Post #135606 30th Mar 2012 12:55am
