![]() | Home > Technical > Interior light problem |
Mine was doing that. You'll probably find the wire is broken to the pin switch or the earthing screw needs cleaning, then the light should stay on as long as the open door makes it stay on
Harald Member Since: 30 May 2012 Location: Flanders Fields Posts: 81 ![]() ![]() ![]() |
But if the cable was broken there would be no earth signal at all, the alarm ECU would not know that the tail door was opened, and the interior light wouldn't work at all...............?
Resistance in the earth could be the cause, as the alarm ECU thinks the tail door was closed again as the resistance is too much. So I'll try to give it a good earth connection with a bypass cable and see what happens. What is important for me, the time the interior light stays on should be the same whether you open the tail door or one of the front doors? Thanks for your advice, Harald |
I have exactly the same fault as the OP on my 50th and I've checked all the door switches, position of light switch etc.
I'm sure the problem lays with the alarm ECU, CarlW's suggestion is an interesting one, ill give that a go next |
Harald,
![]() ![]() ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
If you get out of the drivers door before you open the rear door the light will still be on from the front door opening, then seem to turn off quickly when you open the rear. But if it goes off quickly from just opening the rear door them it probably is an ecu fault. Ray |
