Home > Technical > No Brake lights ??
Skippy R
United Kingdom 1998 Defender 90 300 Tdi SW Chawton White
No Brake lights ??
Seems a bit pathetic to be asking on here but one of you may have the simple answer i'm looking for !!
Got to work this morn and no brake lights, both side lights are ok.
Just had an hour going round car and can't find what the problem is. I've had bulbs out,had plastic 'button' from pedal out,checked fuses and not coming up with anything noticable to show a fault.
Dare i say help ??
Thanks in advance, and go easy on me it's friday Big Cry Dave
98 'S' 90 300Tdi (sold)
07 D3 HSE (now sold)
1993 Scania 143 450 (should have kept that ! )
Post #126427 24th Feb 2012 6:00pm
spudfan
Ireland
Had this happen on a tdi once. Turned out to be a broken feed wire.You need to check if there is power going to the bulb holder in the lights.If not and fuses etc are o.k. then you must have an interruption in power somewhere, most likely a broken wire. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #126434 24th Feb 2012 6:23pm
Skippy R
Yes i've checked that, there is no power at back end so that had crossed my mind but was hoping for something else
Thank you tho Dave
Post #126436 24th Feb 2012 6:28pm
Romadog
take wires of switch and join together. If lights work then switch is faulty. Make sure ignition switch is on Whistle
Post #126439 24th Feb 2012 6:33pm
spudfan
Ireland
Had a switch pack up while driving home, but ALL the lights went. That's how I diagnosed it was a faulty switch Rolling with laughter Drove home on hazard lights alone. 1982 88" 2.25 diesel
Post #126443 24th Feb 2012 6:36pm
Skippy R
[quote="Romadog"]take wires of switch and join together. If lights work then switch is faulty. Make sure ignition switch is on Whistle
You mean the 'button' switch,yes?
I'll try that in morning then Thumbs Up Dave
Post #126445 24th Feb 2012 6:38pm
RED-DOT
Try a circuit tester between the brake light switch with the ignition ON and see if your lights work but i had a mate who had to replace both brake light multi plugs at the back of the lamps on a similar aged Defender tdi, they were not making the connection. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #126448 24th Feb 2012 6:57pm
Skippy R
Everything was fine last night, i know as i was out in dark and when i parked up obviously i can see reflection of the lights, so wonder if we had a 'visit' during the night.....................
Flipping annoying tho Evil or Very Mad Dave
Post #126450 24th Feb 2012 7:05pm
