![]() | Home > Technical > No Brake lights ?? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Had this happen on a tdi once. Turned out to be a broken feed wire.You need to check if there is power going to the bulb holder in the lights.If not and fuses etc are o.k. then you must have an interruption in power somewhere, most likely a broken wire. 1982 88" 2.25 diesel
Skippy R Member Since: 08 Feb 2012 Location: Yorkshire,out 'n'about Posts: 160 ![]() ![]() ![]() |
Yes i've checked that, there is no power at back end so that had crossed my mind but was hoping for something else
Thank you tho Dave 98 'S' 90 300Tdi (sold) 07 D3 HSE (now sold) 1993 Scania 143 450 (should have kept that ! ) |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
take wires of switch and join together. If lights work then switch is faulty. Make sure ignition switch is on
Had a switch pack up while driving home, but ALL the lights went. That's how I diagnosed it was a faulty switch ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
[quote="Romadog"]take wires of switch and join together. If lights work then switch is faulty. Make sure ignition switch is on
![]() You mean the 'button' switch,yes? I'll try that in morning then ![]() 98 'S' 90 300Tdi (sold) 07 D3 HSE (now sold) 1993 Scania 143 450 (should have kept that ! ) |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Try a circuit tester between the brake light switch with the ignition ON and see if your lights work but i had a mate who had to replace both brake light multi plugs at the back of the lamps on a similar aged Defender tdi, they were not making the connection. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Everything was fine last night, i know as i was out in dark and when i parked up obviously i can see reflection of the lights, so wonder if we had a 'visit' during the night.....................
Flipping annoying tho ![]() 98 'S' 90 300Tdi (sold) 07 D3 HSE (now sold) 1993 Scania 143 450 (should have kept that ! ) |
