![]() | Home > Maintenance & Modifications > 2" Lift Kit |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Gents,
Got a 2" lift kit from a friend of mine who went to 3". Set comprises: Bilstein shocks - custom shocks, variably valved and custom damped. Harder on tar than standard, but softer than standard off road. They are also longer than standard, to match the springs. Rear: Progressive OME 762 (medium duty) Front: Progressive OME 761 (medium duty) + spacers (these are for a Disco1, only give 25mm lift) Initial feedback after driving from the workshop back home and to work this working: much better road holding. While the setup is slightly harder than LR setup, it's not bone-jarring. And with the Bilsteins, you don't keep bounding after going over speed bumps - there are many on my daily commute. Will have to try them offroad soon! Before: Click image to enlarge After Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Ok, so this is not much of an offroad trip, but nonetheless:
We drove a few kms of gravel road last weekend, parts of it badly corrugated. SWAMBO even commented how nicely and smoothly this setup is. The bilsteins provide a much better, smoother ride on gravel corrugations than OEM shocks. Since this is mainly the type of road we drive when overlanding, I am pleased with the results. So far (800km) no issues with the front propshaft, but if it does happen, I will fit one of those fancy ones from Bailey Morris 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Started to get some weird vibrations, will probably have to order a Bailey Morris prop
thank Steve. Do you have a link to their shop or know whether they ship to South Africa? Is it this one: http://www.lrsshop.co.uk/content/cor4-prop...dan-630mm? Eish, 750 pounds vs 350 for the BM one... 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
thats the one i bought mine before bailey morris had made their version of it it uses the same joint (im 99% sure it the same being both made in italy )
ao its up to you mate lrs is one of our site sponsors steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
I asked the BM support about which one would fit my needs and this was their response:
shipping costs 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
The Puma already has a a wide angle prop....... Puma 110" SW
Are you sure about this? Looks the same as on the Td5 to me. 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Not wide enough for a lift 2015 2.2 tdci hardtop xs
So, double-cardan or bust then? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
I wouldn´t go for a wider angle prop (IMO). I´m sure SA is full of toyota hilux 4x4 trucks so with a small flange mod you get the best CV prop. Puma 110" SW
I'm taking the landy to a propshaft specialist that my indie uses. I'll see what he says -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Update:
After the clutch was replaced in June, the vibrations from the prop went away. Now that things are loosening up again, the vibrations are back. I think new props will be required. I till try to remove the front prop this weekend and drive around to see if it is the problem. Any advice on how to remove the prop? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Mark the prop flange(s) and the diff flange so that when you put it back together they go back the same do this on both ends. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
