Home > Maintenance & Modifications > 2" Lift Kit
Naks
2" Lift Kit
Gents,
Got a 2" lift kit from a friend of mine who went to 3".
Set comprises:
Bilstein shocks - custom shocks, variably valved and custom damped. Harder on tar than standard, but softer than standard off road. They are also longer than standard, to match the springs.
Rear: Progressive OME 762 (medium duty)
Front: Progressive OME 761 (medium duty) + spacers (these are for a Disco1, only give 25mm lift)
Initial feedback after driving from the workshop back home and to work this working: much better road holding. While the setup is slightly harder than LR setup, it's not bone-jarring. And with the Bilsteins, you don't keep bounding after going over speed bumps - there are many on my daily commute.
Will have to try them offroad soon!
Before:
After
Post #126318 24th Feb 2012 9:03am
Naks
Ok, so this is not much of an offroad trip, but nonetheless:
We drove a few kms of gravel road last weekend, parts of it badly corrugated. SWAMBO even commented how nicely and smoothly this setup is.
The bilsteins provide a much better, smoother ride on gravel corrugations than OEM shocks. Since this is mainly the type of road we drive when overlanding, I am pleased with the results. Thumbs Up
So far (800km) no issues with the front propshaft, but if it does happen, I will fit one of those fancy ones from Bailey Morris Smile --
Post #138949 13th Apr 2012 11:19am
Naks
Started to get some weird vibrations, will probably have to order a Bailey Morris prop Confused --
Post #147721 30th May 2012 4:05pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Or try the equips/ cor4 prop from lrs that's what I've got on my truck it's fit and forget
Not n issue
Thumbs Up
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #147733 30th May 2012 4:35pm
Naks
thank Steve. Do you have a link to their shop or know whether they ship to South Africa?
Is it this one: http://www.lrsshop.co.uk/content/cor4-prop...dan-630mm?
Eish, 750 pounds vs 350 for the BM one... Shocked --
Post #147794 30th May 2012 9:40pm
big steve
thats the one i bought mine before bailey morris had made their version of it it uses the same joint (im 99% sure it the same being both made in italy )
ao its up to you mate lrs is one of our site sponsors
steve 2015 2.2 tdci hardtop xs
Post #147796 30th May 2012 10:01pm
Naks
I asked the BM support about which one would fit my needs and this was their response:
Quote:
Thank you for your enquiry, My feeling is that you will only require a wide angle shaft and not a double cardan as you only have a 2" lift. Once you raise the car it changes the angle on the original props and the yokes bind together as the angle is to great.
Price for the 30 degree shaft will be £173.00 GBP per shaft
Shipping cost's via DHL will be £156.00 for one shaft or £215.20 if you require both front and rear shafts.
shipping costs Shocked --
Post #147871 31st May 2012 10:10am
MK
The Puma already has a a wide angle prop....... Puma 110" SW
Post #147892 31st May 2012 12:17pm
Naks
Are you sure about this? Looks the same as on the Td5 to me. Question --
Post #147899 31st May 2012 12:32pm
big steve
Not wide enough for a lift 2015 2.2 tdci hardtop xs
Post #147903 31st May 2012 12:48pm
Naks
So, double-cardan or bust then? --
Post #147904 31st May 2012 12:50pm
MK
I wouldn´t go for a wider angle prop (IMO). I´m sure SA is full of toyota hilux 4x4 trucks so with a small flange mod you get the best CV prop. Puma 110" SW
Post #147907 31st May 2012 1:01pm
Naks
I'm taking the landy to a propshaft specialist that my indie uses. I'll see what he says --
Post #147909 31st May 2012 1:05pm
Naks
Update:
After the clutch was replaced in June, the vibrations from the prop went away. Now that things are loosening up again, the vibrations are back.
I think new props will be required. I till try to remove the front prop this weekend and drive around to see if it is the problem.
Any advice on how to remove the prop? --
Post #175050 12th Oct 2012 11:46am
Mark the prop flange(s) and the diff flange so that when you put it back together they go back the same do this on both ends. _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #175056 12th Oct 2012 12:15pm
