Home > Maintenance & Modifications > Wiring Wipac SVX lights?
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Can anyone help me? I just bought from offroadrovers a pair of SVX 7" headlights to go into a standard Defender 90 XS. Opening the box I can see the SVX light has a built-in side light and there is a red and black wire from this bulb. Is it as simple as picking up the existing defender side-light wiring and connecting? Therefore having two lights when the existing sidelight is switched on?
Any help would be much appreciated.
M
Post #125580 21st Feb 2012 12:59pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
That's what I did with mine, just chained them off the sidelight. Naughty I know, but the total draw is something like 0.75A on a wire that's already well oversized.
Post #125581 21st Feb 2012 1:00pm
mlightfoot
Thanks - I'm planning on replacing the SVX internal sidelight with an LED bulb and the existing sidelight with a 207 LED bulb, do you know if that will work?
Post #125583 21st Feb 2012 1:09pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
That will work fine, the LED lamps will reduce the current below that of one normal bulb anyway.
Post #125594 21st Feb 2012 1:50pm
mlightfoot
Thanks Guys!
Post #125607 21st Feb 2012 2:50pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Don't do it. The heat generated by the main/dip beam inside the enclosure will take the LED sidelight way outside it's operating temperature spec. It will not survive very long.
The LED in the existing external side light will be fine.
Pete
Post #125617 21st Feb 2012 3:49pm
mlightfoot
Thanks Pete Shocked
Post #125618 21st Feb 2012 3:54pm
XS Pete
No problem. I made this mistake so you don't have to!
Pete
Post #125627 21st Feb 2012 4:29pm
The Main bulbs go upto something like 220'C if I remember correctly Shocked
Post #125631 21st Feb 2012 5:09pm
XS Pete
Too true, and a standard 5050 SMD LED is operating outside its comfort zone above 85C.
Pete
Post #125633 21st Feb 2012 5:19pm
Pete
Easy to not realise though! LED type bulbs also tend to be plasticky often too. Personally I don't like LED's seem too directional on light output to me Whistle
Post #125639 21st Feb 2012 5:44pm
mlightfoot
Thanks for all your help:)
Post #125876 22nd Feb 2012 1:04pm
