![]() | Home > Maintenance & Modifications > Wiring Wipac SVX lights? |
| twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655
That's what I did with mine, just chained them off the sidelight. Naughty I know, but the total draw is something like 0.75A on a wire that's already well oversized.
| mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86
Thanks - I'm planning on replacing the SVX internal sidelight with an LED bulb and the existing sidelight with a 207 LED bulb, do you know if that will work?
| Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384
That will work fine, the LED lamps will reduce the current below that of one normal bulb anyway.
Thanks Guys!
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
Don't do it. The heat generated by the main/dip beam inside the enclosure will take the LED sidelight way outside it's operating temperature spec. It will not survive very long. The LED in the existing external side light will be fine. Pete |
Thanks Pete
No problem. I made this mistake so you don't have to!
Pete |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
The Main bulbs go upto something like 220'C if I remember correctly
Too true, and a standard 5050 SMD LED is operating outside its comfort zone above 85C.
Pete |
Easy to not realise though! LED type bulbs also tend to be plasticky often too. Personally I don't like LED's seem too directional on light output to me |
Thanks for all your help:)
