![]() | Home > Maintenance & Modifications > roof gutter... |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Some sort of sealant , im sure a grown up will be along shortly to tell us what it is
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Nothing to worry about, just the sealant settling itself
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 ![]() ![]() ![]() |
cool, so its like a strip of draught excluder then, or similar stuck into the gutter?
it's got a pliable feel when poked... i'll glue the paint flake down with that clear laquer paint stick that comes with the twin stick jobbie... ![]() |
or if you can get some DumDum and work it into the surface of the gutter, it will fill all the cracks.
whilst your up there, have a look at the gutter around the rear door and make sure it's sealed properly, that's the spot I had a leak in my td5, it would seep in the run along the internal rails and all over me when I went around corners. |
Whats DumDum? other than a bullet or a pop duo (quoting google)
this is dumdum ... find it, buy it
