Home > Maintenance & Modifications > roof gutter...
ti-fat-man
United Kingdom 2011 Defender 110 Puma 2.4 USW Alpine White
roof gutter...
folks, whats the material finish under the paint coat lining the roof gutter.
i've got a lifted flake, shall i pick it?
Post #124156 15th Feb 2012 6:10pm
ibexman
Some sort of sealant , im sure a grown up will be along shortly to tell us what it is Thumbs Up
Post #124159 15th Feb 2012 6:13pm
Zagato
Nothing to worry about, just the sealant settling itself Rolling Eyes I've touched up the hairline cracks in mine with the lacquer you get with the touch up paint. You could just paint and lacquer yours. Some have taken theirs back to get re-done under warranty, even had the roof off and the whole lot dug out, resealed and re-sprayed Rolling Eyes but the likely hood is that it will happen again, a dab of paint will sort it, you can't see it! Thumbs Up
Post #124167 15th Feb 2012 6:43pm
ti-fat-man
cool, so its like a strip of draught excluder then, or similar stuck into the gutter?
it's got a pliable feel when poked...
i'll glue the paint flake down with that clear laquer paint stick that comes with the twin stick jobbie... Thumbs Up
Post #124189 15th Feb 2012 8:18pm
or if you can get some DumDum and work it into the surface of the gutter, it will fill all the cracks.
whilst your up there, have a look at the gutter around the rear door and make sure it's sealed properly, that's the spot I had a leak in my td5, it would seep in the run along the internal rails and all over me when I went around corners.
Post #124191 15th Feb 2012 8:25pm
ti-fat-man
Whats DumDum? other than a bullet or a pop duo (quoting google)
Post #124239 15th Feb 2012 10:20pm
this is dumdum ... find it, buy it Thumbs Up
Post #124257 15th Feb 2012 10:50pm
