![]() | Home > Maintenance & Modifications > Steering damper? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
I would suggest OE or Terrafirma. Are you sure the vibration isn't caused by your wheels being un-balanced or out of alignment?
Bearcat Member Since: 09 Dec 2011 Location: Dublin Posts: 57 ![]() ![]() |
Point taken.....I'm going to fit the bf goodridges, balance and track it and see. I just feel there's a lot of undampened play in the steering. Current...07 90 Puma commercial
Porsche 930 1988 (laid up) Previous Td5 90 & V8 90 |
Good choice! I would see what it's like once you have them fitted and balanced ect. And if your still not happy with it try a new steering damper. Perhaps this: http://www.devon4x4.com/index.php?page=sho...;Itemid=14 Or this maybe: http://www.devon4x4.com/index.php?page=sho...;Itemid=14 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6049 ![]() ![]() |
Best steering damper is an OME, but as long as it offers equal resistance in extension and compression, it is ok. If you have a vibration and changing the damper stops it, you are just hiding the problem that still exists. It will probably be unbalanced wheels, pan hard rod bushes, or swivel preload.
Just my opinion, though. Andy |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
I had similare and was just living with it, then had a leak on the seal to the ball joint that needed things ajusting (don't know what
![]() no real facts I know but may be worth a look Mark |
