Home > Maintenance & Modifications > Steering damper?
Bearcat
Ireland
Steering damper?
How do you know you need a new one? For me the slightest bit of wheel vibration translates into noticeable steering wheel shake at speed. I'm changing my Tyres soon and want things right.
Also can you point me to a steering damper that is a popular choice?
Many thanks Current...07 90 Puma commercial
Porsche 930 1988 (laid up)
Previous Td5 90 & V8 90
Post #123190 11th Feb 2012 9:58am
I would suggest OE or Terrafirma. Are you sure the vibration isn't caused by your wheels being un-balanced or out of alignment?
Post #123202 11th Feb 2012 11:37am
Bearcat
Ireland
Point taken.....I'm going to fit the bf goodridges, balance and track it and see. I just feel there's a lot of undampened play in the steering. Current...07 90 Puma commercial
Post #123203 11th Feb 2012 11:44am
Good choice! I would see what it's like once you have them fitted and balanced ect. And if your still not happy with it try a new steering damper. Perhaps this: http://www.devon4x4.com/index.php?page=sho...;Itemid=14 Or this maybe: http://www.devon4x4.com/index.php?page=sho...;Itemid=14
Post #123204 11th Feb 2012 11:48am
landy andy
Best steering damper is an OME, but as long as it offers equal resistance in extension and compression, it is ok. If you have a vibration and changing the damper stops it, you are just hiding the problem that still exists. It will probably be unbalanced wheels, pan hard rod bushes, or swivel preload.
Just my opinion, though.
Andy
Post #123215 11th Feb 2012 1:35pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
I had similare and was just living with it, then had a leak on the seal to the ball joint that needed things ajusting (don't know what Embarassed ) and the vibration that always hapened on a regulare route stoped, for a bit at least,
no real facts I know but may be worth a look
Mark
Post #123235 11th Feb 2012 3:48pm
