Home > My Defender > Do I have a 2" or 4" lift?
RRUK
I looked in the Owners manual and when I measured the height of my 90's roofline, it is 4 inches higher than standard. (just over 80 inches)
Admittedly it stand on 265/70/17 tyres, which may add something too, but going from this photo, would you say this car has a 2 or 4 inch lift?
 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #119591 29th Jan 2012 7:38pm
K9F
4" By my reckoning? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #119594 29th Jan 2012 7:46pm
Zagato
Can't see pic Sad clicking red cross doesn't work either!
Post #119595 29th Jan 2012 7:50pm
K9F
Did for me momentarily but doesn't now???? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #119598 29th Jan 2012 7:52pm
RRUK
Sorry, deleted the wrong picture from the gallery, all sorted now 2016 D4 HSE
Post #119606 29th Jan 2012 8:16pm
K9F
The angle on the first picture makes it look higher....
4" on the first 2" on the second....Sorry.... Embarassed Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #119628 29th Jan 2012 9:06pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Do you have to step up or jump up to get in, my current is a 2" lift, but neighbour has a 4" which I have to launch and swivel to get in, and I'm over 6ft, don't know how people use anything over 2-3" lifts without step ladders Very Happy
Looks a 2 or 3" lift Thumbs Up ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #119665 29th Jan 2012 10:19pm
RRUK
It's a definite jump up, but I've not got in and out than a 2" lifted car to compare!
I'm guessing if I want to put it back to 2" I'll need to get a full set of springs and shocks to ensure all is right.
Is it an easy DIY job? 2016 D4 HSE
Post #119676 29th Jan 2012 10:38pm
markb110
I would say that it is a 2" lift.
If it were a 4" with stardard radius and trailing arms you will see that the springs won't look even, ie looking from front to rear at the front springs the coils will look more open at the front and closer together at the rear.
This is because the axle as a whole is rolling forward. Think of the hands of a clock sitting at 12 and six when normal but 10 and 8 for a 4" inch lift.
Unless corrected it would be bloody horrible to drive, crash over bumps and won't self centre. Also the the diff to prop angles will be noticably wrong and let's not forgot the stress on the brake lines if used off road
Hope that helps
Mark
Post #119677 29th Jan 2012 10:41pm
T1G UP
i'd say 2"
its a hop up in with a 2" lift
if you want it lower so say with a 1-1.5" lift then i use to run standard 90 rears on the front and a set of red a whites on the rear
Post #119680 29th Jan 2012 10:49pm
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
3 Rolling with laughter
Post #119685 29th Jan 2012 11:37pm
CR
Post #119686 29th Jan 2012 11:37pm
