![]() | Home > My Defender > Do I have a 2" or 4" lift? |
4" By my reckoning? If you go through life with your head in the sand....all people will see is an ar5e!!
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Can't see pic
Did for me momentarily but doesn't now???? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2033 ![]() ![]() |
Sorry, deleted the wrong picture from the gallery, all sorted now 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
The angle on the first picture makes it look higher....
4" on the first 2" on the second....Sorry.... ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Do you have to step up or jump up to get in, my current is a 2" lift, but neighbour has a 4" which I have to launch and swivel to get in, and I'm over 6ft, don't know how people use anything over 2-3" lifts without step ladders
![]() Looks a 2 or 3" lift ![]() Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
It's a definite jump up, but I've not got in and out than a 2" lifted car to compare!
I'm guessing if I want to put it back to 2" I'll need to get a full set of springs and shocks to ensure all is right. Is it an easy DIY job? 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2673 ![]() ![]() ![]() |
I would say that it is a 2" lift.
If it were a 4" with stardard radius and trailing arms you will see that the springs won't look even, ie looking from front to rear at the front springs the coils will look more open at the front and closer together at the rear. This is because the axle as a whole is rolling forward. Think of the hands of a clock sitting at 12 and six when normal but 10 and 8 for a 4" inch lift. Unless corrected it would be bloody horrible to drive, crash over bumps and won't self centre. Also the the diff to prop angles will be noticably wrong and let's not forgot the stress on the brake lines if used off road Hope that helps Mark |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
i'd say 2"
its a hop up in with a 2" lift if you want it lower so say with a 1-1.5" lift then i use to run standard 90 rears on the front and a set of red a whites on the rear |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
3
3
