![]() | Home > Puma (Tdci) > Speedo or lack of it! |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
My speedo has stopped working? Is there a fuse or somethin that might have broke? Seem to happen after I washed it!?? 90 Puma HT
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Hi jammer
I dont know about if theres a fuse just for the speedo i would guess its for the complete instrument cluster, I had this on a 07 plate 110 puma once and it was the speedo drive on the transfer box that had seized up (not the electric transducer) it might be this worth a try if all else fails Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Anyone know where it's too? And I'll check that first
When the transducer is off you can use a screwdriver to gently prize the drive out of the transfer box and it was that what was seized on the one I did
interesting... if it's the head unit, it's a garage job as the whole head unit will need to be replaced. the good news is the instrument clusters are about 180, the bad news is LR have to re-sync the head to the rest of the electronics in the vehicle (10AS etc)
you can pick up 2nd hand units from scrappys for 50-70 though and they can be sync'd the same as a new one ![]() |
Had a fiddle with my speedo, the bit which is connected to the trans box, must of forgot to put the plug back on as I drove to work today and it still doesn't work and drives like a flat slow piece of
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
i am lost a bit here, you forgot to refit the plug and now performance is massively down? Cheers
