Home > Puma (Tdci) > Speedo or lack of it!
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
My speedo has stopped working? Is there a fuse or somethin that might have broke? Seem to happen after I washed it!?? 90 Puma HT
Post #118745 26th Jan 2012 8:58pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Hi jammer
I dont know about if theres a fuse just for the speedo i would guess its for the complete instrument cluster,
I had this on a 07 plate 110 puma once and it was the speedo drive on the transfer box that had seized up (not the electric transducer) it might be this worth a try if all else fails
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #118758 26th Jan 2012 9:16pm
Jammer600
Anyone know where it's too? And I'll check that first Smile 90 Puma HT
Post #118768 26th Jan 2012 9:28pm
jst
passenger side of the Transfer box, between rear of handbrake and the gbox casing.
wires will be going down to transducer.
remove the plug (3 wire?)
8mm or 10mm nut above holding the transducer onto the side of the box
remove transducer.
if you refit the plug and ign on and spin the transducer you should see speedo needle move (it will take 2pax!)
also check the small square keyway in the side of the T box that the transducer sits in rotates. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #118803 26th Jan 2012 10:31pm
derbywill
When the transducer is off you can use a screwdriver to gently prize the drive out of the transfer box and it was that what was seized on the one I did
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #118830 27th Jan 2012 2:09am
interesting... if it's the head unit, it's a garage job as the whole head unit will need to be replaced. the good news is the instrument clusters are about 180, the bad news is LR have to re-sync the head to the rest of the electronics in the vehicle (10AS etc)
you can pick up 2nd hand units from scrappys for 50-70 though and they can be sync'd the same as a new one Thumbs Up
Post #118841 27th Jan 2012 8:27am
Jammer600
Had a fiddle with my speedo, the bit which is connected to the trans box, must of forgot to put the plug back on as I drove to work today and it still doesn't work and drives like a flat slow piece of Censored !! 90 Puma HT
Post #121094 3rd Feb 2012 11:08pm
jst
i am lost a bit here, you forgot to refit the plug and now performance is massively down? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #121131 4th Feb 2012 8:06am
