Home > Technical > Safari Snorkel air filter question! |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
I am taking my 110 for it's first service tomorrow and was wondering about the air filter! I fitted a Safari Snorkel but I'm pretty sure I left the air filter in place Should I have done that? How can it be replaced if the snorkel is permanently covering the wing hole. I've thrown the instructions away so don't know if it should still be in place or not!
It's this one http://www.safarisnorkel.com/snorkel/ss581hf/ss581hf.htm |
15th Jan 2012 5:51pm |
Thanks Tim
15th Jan 2012 6:05pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
I thought it was April 1st when i read that
15th Jan 2012 6:49pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
I did think twice But then saw it was Zag, so must be genuine California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
15th Jan 2012 6:58pm |
This is the wing air filter of course How do you change the air filter on the wing from inside? Last edited by Zagato on 15th Jan 2012 7:14pm. Edited 2 times in total |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
Be nice matt, in fairness zags probably polished it so much its turned to dust and disappeared 2004 TD5 Defender 90 xs station wagon
15th Jan 2012 6:59pm |
I'm talking about the wing air filter, do pay attention at the back! How do you replace it from inside or should I have taken the filter out before fitting the Snorkel? Anyone know or got fitting instructions! Ta. |
15th Jan 2012 7:13pm |
Zag - did you remember to remove all the packaging from inside the RAI - bubble wrap etc before you fitted it
15th Jan 2012 7:20pm |
I have a nasty feeling I should have removed the filter before fitting the snorkel Can't find any instructions on the web, old Def2 links not working!
15th Jan 2012 7:26pm |
*delete*
15th Jan 2012 7:35pm |
Anyone got fitting instructions or knows would be very helpful, have Googled 8 pages and no instructions
Coming to the conclusion I should have taken it out, ! |
15th Jan 2012 7:39pm |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 |
Has the Puma got more than one air filter then? Current:D4 HSE
Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
15th Jan 2012 7:55pm |
Yes there is a filter the same shape as the side wing hole, I don't think it should be there with the Snorkel on as I can't see any easy way of replacing it from inside the wing. Unless someone who knows otherwise I think I could be having fun and games getting it back out again i.e. base of Snorkel will need unscrewing or more likely the whole snorkel will need to come off altogether to get it out If I can't get at it from inside which I don't think I can
15th Jan 2012 8:04pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
No filter behind the wing plate on mine (2009 110).
Just frozon my doo dahs off going out to the garage to double check in my box of 'bits removed' and just the plastic plate. Of course land Rover may have forgotten to fit it All the dealer does at service time is replace the filter in the air box - if they can be bothered Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
15th Jan 2012 8:11pm |
