Home > Td5 > Wastgate contorl valve/module
Arbman Al
Just been checking what other pipes etc I need to finish the converison to TD5 and found the small vacuum pipes to the turbo go to a module which should be bolted to the engine.
I can't see one on mine, nor any markings to show where one would have been.
Are they fitted to all Defender TD5, and if so can they be fitted elsewhere? Where do the pipes to the module go (3 of them I think)
Cheers...Al 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #113481 8th Jan 2012 2:56pm
wslr
The modulator is only fitted to Discovery Td5, not Defender.
Post #113502 8th Jan 2012 4:05pm
Arbman Al
Cheers. Thats one less thing to buy then Thumbs Up
Where does the pipe that goes onto the wastegate connect to then?
There is a T in the brake vacuum pipe that does not have anything connected to it, is it to here? 1996 Defender 130 converted to TD5 and auto
Post #113507 8th Jan 2012 5:02pm
bell-auto-services
It goes to the intercooler metal hose that with rubber comes from the turbo to the intercooler UK passenger side.
Post #113513 8th Jan 2012 5:39pm
landy andy
As Pete said,
The T in the vacuum pipe is for the EGR Valve I would think.
Andy
Post #113514 8th Jan 2012 5:42pm
Arbman Al
landy andy wrote:
As Pete said,
Andy
I may be being thick here Rolling Eyes but I am pretty sure (until I have a look tomorrow) that the two pipes on the egr valve go to the modulator on the wing (two solenoid modulator). I can't see where a pipe from the 'T' in the brake vacuum servo pipe connects to.
Microcat and the manual don't shed any light on this matter... 1996 Defender 130 converted to TD5 and auto
Post #113572 8th Jan 2012 8:00pm
bell-auto-services
The vac pipe on the brake pipe has a T near the alternator but landrover do do a pipe without the T fitted.
Post #113599 8th Jan 2012 8:44pm
bell-auto-services
in the picture you can see two red arrows, the T is behind the top red arrow hidden by the larger black pipe. the bottom red arrow is what has been taken off the T. From the T it goes to the solonide on the inner wing.
Dont worry about it, blank the egr valve and vacuum hose and remove the vacuum pipes and solonides totaly Smile
Post #113601 8th Jan 2012 8:53pm
Arbman Al
Thanks again Pete Thumbs Up
Is the connector a little right angled boot, as I found one lying on the floor the other day before the engine went in, so hopefully will find a pipe with no connector on the end.... 1996 Defender 130 converted to TD5 and auto
Post #113608 8th Jan 2012 9:14pm
bell-auto-services
no problem, yes its the right angled boot as seen on the end of the lower red arrow.
PEte
Post #113609 8th Jan 2012 9:18pm
Arbman Al
Looking at the pipe work for the egr modulator on the wing and I have found this:
The two clear/white tubes are connected by a joiner and then the one white tube has been plugged into a joiner that has two green tubes coming into it from the modulator. The 't' on the brake vacuum pipe is unconnected to anything.
Two blue tubes go to the egr valve as normal.
Is this someone's attempt at by-passing something?
Should it be connected up as per the Haynes manual?
Post #114012 10th Jan 2012 10:20am
landy andy
I would remove the egr valve, and all the pipe work completely.
Then get vac hose that does not have the "T" in it.
Andy
Post #114065 10th Jan 2012 4:29pm
Arbman Al
Andy
I probably will eventually, but for now I just need to get it connected up so that I can get the engine running asap.
Can I leave it like it is (done by previous owner), and blank off the T in the servo pipe? 1996 Defender 130 converted to TD5 and auto
Post #114075 10th Jan 2012 5:44pm
landy andy
Yes, most do just that. It is only the nicer kits that come with new vac hose.
Andy
Post #114084 10th Jan 2012 6:22pm
Arbman Al
Andy
Thanks Andy.
Post #114119 10th Jan 2012 8:28pm
