![]() | Home > Td5 > Cable from battery to underseat fusebox |
Do you have all the bits for the td5 conversion yet Al? i@m breaking a td5and have a full engine conversion for sale ![]() |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 ![]() |
Nearly finished now, so should be ok - thanks anyway. Apart from the cable mentioned above... 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287 ![]() ![]() ![]() |
Hi Arbman Al have sent you a massage with my contact number, give me a call I will help you.
Thansk Ash ![]() |
Thanks for the advice earlier Ash. Top bloke!! 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6217 ![]() ![]() ![]() |
The cable is the main power feed to the underseat fusebox.
One end has the battery terminal, the other is a right angled lug with a hole through it, which fits into the fusebox and is screwed down. The cable also has 2 zip ties that attach to a couple of the bolt ends that poke through the underside of the top of the seatbox...the ties have a part that pushes up onto threaded bolts and secures them in place. you don't really want that cable dangling and catching something as it's +ve direct from the battery! |
Does this cable run inside the cab behind the seats, or under the cab?
Does it matter, as very tricky making 2" holes in the side of the seat box for the grommets. 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
It runs under the seatbox.
ok cheers. Any tips on cutting large holes in the side of the drivers seat box? Engine and gearbox back in now.... 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18020 ![]() ![]() ![]() |
Q-Max sheet metal punch http://www.lawson-his.co.uk/scripts/produc...%20Cutters |
Hole saw? linky <-----
That is what I used in the end. There was more room underneath to use a drill than I thought with the gearboxes back in ![]() 1975 Triumph Stag 3.0 V8 |
