Home > Td5 > Cable from battery to underseat fusebox
Arbman Al
I am converting my 300tdi to a TD5.
Putting the ecu under the drivers seat along with a fusebox. There is a cable (I think) that runs behind the seats from the battery to the fusebox.
Could someone confirm that this is correct and what fittings are on the end of the cable (photo would be good Thumbs Up ), as I want to make one up.
I think there are also relays under there as well, are these just normal relays from an auto shop?
Cheers...Al
Post #112112 4th Jan 2012 7:30pm
T1G UP
Re: Cable from battery to underseat fusebox
Cheers...Al
Do you have all the bits for the td5 conversion yet Al? i@m breaking a td5and have a full engine conversion for sale Whistle
Post #112176 4th Jan 2012 9:15pm
Arbman Al
Cheers...Al
Nearly finished now, so should be ok - thanks anyway. Apart from the cable mentioned above... 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #112178 4th Jan 2012 9:18pm
T1G UP
Cheers...Al
you can buy mine for £1500 Rolling with laughter
Post #112186 4th Jan 2012 9:30pm
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Hi Arbman Al have sent you a massage with my contact number, give me a call I will help you.
Thansk Ash Cool
Post #112202 4th Jan 2012 9:53pm
Arbman Al
Thansk Ash Cool
Thanks for the advice earlier Ash.
Top bloke!! 1996 Defender 130 converted to TD5 and auto
Post #112263 4th Jan 2012 11:25pm
The cable is the main power feed to the underseat fusebox.
One end has the battery terminal, the other is a right angled lug with a hole through it, which fits into the fusebox and is screwed down.
The cable also has 2 zip ties that attach to a couple of the bolt ends that poke through the underside of the top of the seatbox...the ties have a part that pushes up onto threaded bolts and secures them in place. you don't really want that cable dangling and catching something as it's +ve direct from the battery!
Post #112446 5th Jan 2012 2:52pm
Arbman Al
Does this cable run inside the cab behind the seats, or under the cab?
Does it matter, as very tricky making 2" holes in the side of the seat box for the grommets. 1996 Defender 130 converted to TD5 and auto
Post #114463 11th Jan 2012 10:04pm
It runs under the seatbox.
Post #114466 11th Jan 2012 10:10pm
Arbman Al
ok cheers.
Any tips on cutting large holes in the side of the drivers seat box? Engine and gearbox back in now.... 1996 Defender 130 converted to TD5 and auto
Post #114489 11th Jan 2012 11:00pm
Q-Max sheet metal punch
http://www.lawson-his.co.uk/scripts/produc...%20Cutters
Post #114500 11th Jan 2012 11:53pm
Hole saw? linky <-----
Post #114522 12th Jan 2012 8:53am
Arbman Al
That is what I used in the end. There was more room underneath to use a drill than I thought with the gearboxes back in Smile 1996 Defender 130 converted to TD5 and auto
Post #114734 12th Jan 2012 8:47pm
