Home > For Sale & Wanted > WTD to Borrow Td5 Throttle Pedal Assembly |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
2 or 3 pin. i have one here. not sure which one it is though. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
2nd Jan 2012 3:30pm |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 |
Blimey that was Quick Thanks Im just about to take mine off to inspect it and try and clean it up so will let you know. Its an EU3 engine though.. Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
2nd Jan 2012 3:36pm |
let me know and i will go see what the one i have is. Cheers
2nd Jan 2012 3:43pm |
Not sure what you mean by 2 or 3 Pins as mine has 9 i think.
I did notice that the wiring side Plug has got 3 Pins with no electrical contacts in the Block. One each side low down and the other central up on the higher row in a triangle shape. Do you know what i mean? Decided not to remove mine as it seems a PITA to get off with only 1 person so i cant see that well. Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
2nd Jan 2012 4:03pm |
