![]() | Home > For Sale & Wanted > WTD to Borrow Td5 Throttle Pedal Assembly |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8371 ![]() ![]() ![]() |
2 or 3 pin. i have one here. not sure which one it is though. Cheers
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Blimey that was Quick ![]() Im just about to take mine off to inspect it and try and clean it up so will let you know. Its an EU3 engine though.. Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
let me know and i will go see what the one i have is. Cheers
Not sure what you mean by 2 or 3 Pins as mine has 9 i think.
I did notice that the wiring side Plug has got 3 Pins with no electrical contacts in the Block. One each side low down and the other central up on the higher row in a triangle shape. Do you know what i mean? Decided not to remove mine as it seems a PITA to get off with only 1 person so i cant see that well. Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
