Home > For Sale & Wanted > Warn 9.5ti Winch for Sale
Page 2 of 2 <12
TJ101
Easiest winch to fit,
Bolt to winch bumper, run both Pos+ and Neg- cables back underneath to the battery box, connect up, Plug in the remote and away you go, not separate solenoid or control box,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #111582 2nd Jan 2012 9:07pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Just looked again on topix the solenoid in the genuine kit under the passenger seat is for the winch cut off,
Post #111593 2nd Jan 2012 9:35pm
Whistle Thumbs Up but agree a great winch and pizza easy to fit if you have the extended "Defender" cables Thumbs Up
Post #111594 2nd Jan 2012 9:39pm
mse
Thought that might be what you were looking at...warn i think do one cheaper than Land Rover's - although a simple key isolator switch like this is by far the most simple and is by its nature...keeping it simple; which has its merits! Mike
Post #111631 2nd Jan 2012 11:09pm
TJ101
One tip mind !!
Cut off the pathetic, often loose, neg terminal and fit a proper one, with an extended bolt, and 2 nuts,, one to lock the batt terminal, and the other to lock the leads taken for that terminal California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #111634 2nd Jan 2012 11:12pm
Page 2 of 2 <12
