Home > Puma (Tdci) > Brake failure
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Brake failure
Hi
To times - once in may, and once today the brakes on my defender did not work? When I was doing about 60 kmh I stepped on the brakes and the pedal acted like the engine was turned off! When trying several times (really fast Shocked ) the brakes suddenly acted normal again. As mentioned it has happened 2 times . I have no idea about what it could be - seems unlikely that the vacuum pump is broken as everything works perfectly again - any ideas ? By the way my defender is without ABS.
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #110260 27th Dec 2011 8:30pm
MK
Not sure, but check on the vacuum hose to the brake servo. Puma 110" SW
Post #110271 27th Dec 2011 8:59pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
had a similar issue on my 300tdi - check the caliper pistons are OK and not sticking, especially the rear ones, you may also find that one of the rear pads is less worn than the rest, eg where the piston is sticking BM52
Post #110281 27th Dec 2011 9:42pm
