Home > Technical > FRONT HEATED GLASS
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
FRONT HEATED GLASS
i want to change my front window screen to heated one.
i find that the switch is YUG000460LNF.
is it needed and wiring loom or is existed as at Disco 2.
if no, can you tell me the part number?
thanks www.newfoundland.gr
Post #109334 23rd Dec 2011 10:20am
BigRuss
I think all the wiring is already there Russell
2011MY 110 XS USW Black
Post #109349 23rd Dec 2011 11:04am
Grockle
the loom isn't there if it's not std fit or has been a factory fitted option,I had to wire ours in on the TD5 County we had. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #109356 23rd Dec 2011 11:08am
BigRuss
I stand corrected Bow down Russell
Post #109358 23rd Dec 2011 11:09am
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
For the windscreen in my 110DC I used the redundant wiring for the heated rear screen, so have the light up switch, and the dash warning light, but no auto off relay. Still excellent, as it only takes a minute or so to clear.
There are choices of colours for the screen itself - green or clear - I went clear. 2001 TD5 110 DCPU in Bonatti Grey
Post #109373 23rd Dec 2011 11:45am
BigRuss
Yeah I wonder why they didn't put an auto off switch in the rear screen like they used for the front, I normally keep an eye on the lights and turn the rear screen off as so as I notice the front one has turned off Thumbs Up Russell
Post #109407 23rd Dec 2011 1:27pm
pouf
i am asking about part number cause if there is no p.num., wiring loom is existed www.newfoundland.gr
Post #109498 23rd Dec 2011 4:54pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
If the heated windscreen is not fitted from the factory, its extremely unlikley that the wiring will be present. Where fitted, its part of the main wiring loom, not a separate part.
LR seem to have gone away from the "one size fits all" philosophy. Microcat lists 40 different main loom assemblies for the 2007 Defender Shocked
Post #109543 23rd Dec 2011 6:35pm
Alive Tuning
Make sure you buy a genuine land rover screen. The britpart ones have a hiddeous silver strip at the top and bottom, and use a bazarre three wire arrangement! Shocked
Post #109547 23rd Dec 2011 7:03pm
Romadog
Use www.heatedwindscreens.com
And the problem with 3 wires is..?
Post #109552 23rd Dec 2011 7:20pm
Alive Tuning
Romadog wrote:
And the problem wit h 3 wires is..?
There are no wiring instructions with the britpart screens, just three thick wires with no connectors fitted. Connect the original connectors to the screen, and it won't work. There's that mysterious stray wire in the middle. Confused
Looks hideous with the silver strips, so use original equipment instead, which has the correct spade connectors on each side.
Post #109555 23rd Dec 2011 7:29pm
pouf
yes, it is ok.
but if it is needed another main loom just for one heated glass, you have to sell one of your ..........kidney Laughing .
it must be something else....................
there is p.n. of screen(LR009821)
there is p.n. of switch(YUG000460LNF)
where is the loom?????? Big Cry Big Cry
(of course we are talking about genuine land rover screen) www.newfoundland.gr
Post #109558 23rd Dec 2011 7:39pm
